Topic: Setting Up the UFX with a Dangerous D-Box for Analogue Summing
HI,
I am setting up a UFX with a Dangerous D-Box for analogue summing, and I am running into a problem.
I am using the 8 analogue outputs of the UFX in pairs to go out to the D-Box (1-2,3-4, etc.), then using input 1-2 to come in with the summed stereo signal, and them using AES 13-14 as my main monitor outs to go to the D-Box and monitors.
I re-routed the volume pot output for the main outs to ADAT 1-2, so that analogue 1-2 in a normal analogue output.
In Logic, I routed the same way, 1 bus for each output pair (drum stem, gtr stem, etc.) and a return track with input from 1-2 (the summed signal) and output to 13-14.
The problem is the UFX is still somehow sending the main output that is supposed to be on output 13-14 to output 1-2 as well. Could this be a Totalmix issue? I have tried what I thought was every routing, but I am still having the same issue.
Could it be a firmware thing? I haven't updated in a while. Also, my studio is not online, I transport my iMac to my house to do all the updates, so do I need to take the UFX as well, or can the new drivers be loaded and then updated to the UFX later.
Lastly, the D-Box and UFX are not syncing via AES, so maybe this has something to do with it?
Thanks for any help!!!
