Topic: RMS voltage output of AO4S-192 AIO
Hi there,
I am sending a 0dBFS sine signal (200Hz), created via MATLAB, to the output of the HDSP 9632 card. The output level setting is -10dBV, which means that 0dBFS produces +2dBV (rms).
Now, if I am not wrong, I would expect to measure an rms voltage (using a digital multimeter) of 10^(2/20) = 1.26V between the hot and cold pins (tip/ring of the TRS plug).
Instead, I measure roughly double that, i.e. 2.49V. Would that mean that contrary to what I assumed above, I am wrong and +2dBV refers to half of the rms measured between the balanced connection wires?
Thanks for the assistance,
Chris
Re: RMS voltage output of AO4S-192 AIO
You overlooked the balanced setting in the Settings dialog.
Hmmm, fair enough... Thanks MC. All working as expected now smile
