Topic: Digiface HDSPe Setings - Sample Rate Not Changing
I've just upgraded to OSX Lion 10.7.5 and updated my Digiface's drivers to version 3.04 (firmware revision 18).
The Sample Rate checlbox in the HDSPe Settings dialog doesn't have any effect.
I can change the sample rate in Audio MIDI setup but the HDSPe settings dialog doesn't change anything.
I'm running it with an Orpheus, but I've also tried switching the Orpheus off and running the Digiface on it's own as clock master. I've also tried changing the sample rate in HDSPe settings and then rebooting but the sample rate can only be changed in Audio MIDI setup.
Is this normal behavior? What am I missing?
Danno
HDSPe Digiface via ExpressCard Adapter
Fireface UFX III & UCX I
