Topic: NEED HELP with M/S Recording
HI,
Can somebody please explain to me exactly how to utilize the M/S mode in Fireface UFX. I fully understand the principles, but am not at all clear on what totalmix is doing when this mode is enabled... Here is my setup:
MIC/LINE Input 9 - Supercardiod AKG 414
MIC/LINE Input 10 - Figure-8 AKG 414
Under 'Settings' in Totalmix, for Channel 9:
1) I select 'STEREO', which then causes Channel10 to disappear (folding into 9 to create the 'stereo' channel)
2) I select MS PROC
3) I select phase-invert R
Now, when I setup my DAW (Logic 9 ) to record this stereo input... where is my MONO MID channel? I assume it is on the LEFT of the totalmix stereo output. How then do I split up the RIGHT channel of the totalmix stereo output to split into a stereo channel in Logic. I could do it the old-fashioned way, split the channel, phase-invert one side, etc.--BUT then what is the MS Proc actually doing in totalmix if I have to still set it up the old-fashioned way?
Very confused... and need help ASAP! Hoping to record later this afternoon!
Cheers,
amb
