Topic: Using babyface as multi-channel DAC for room correction
Hi, Im interested in a babyface to use as follows; hooking a microphone up and recording a test tone played out the digital output into an external DAC / AMP. This is to measure the response of a room. Then I would like to playback 4 channels; two on a digital output an two on analog outputs. Can this all be done with the Babyface? Also is it bit perfect, that is no upsampling or SRC?
Thank you.
Re: Using babyface as multi-channel DAC for room correction
All answers - yes.
Wow! Excellent. The author of the room correction software (Acouarte) has also reccomended your products. I am surprised that USB 2.0 can support the bandwidth for 4 channels of 24/192 data streaming. I have a M-Audio Transit and it barely makes 2 ch 24/96. This is great news.
Also mind that the BF does have 4 separate analog outputs, 3/4 being unbalanced (phones), though.
Daniel, can I use the two channels of analog output and then drive an external DAC via the S/PDIF to get 4 channels? Can the headphone outs be used as single ended analog outs?
6
Yes (= 6 channels) and Yes.
