Topic: Using babyface as multi-channel DAC for room correction
Hi, Im interested in a babyface to use as follows; hooking a microphone up and recording a test tone played out the digital output into an external DAC / AMP. This is to measure the response of a room. Then I would like to playback 4 channels; two on a digital output an two on analog outputs. Can this all be done with the Babyface? Also is it bit perfect, that is no upsampling or SRC?
Thank you.
