Topic: Change in levelling from flash?
I just switched over to the HDSPe card from the PCI card and while I was at it flashed the firmware on my Multiface. For some reason on this new system, I find that my tracking levels are a lot hotter.
I'm recording stuff with the exact same hardware and settings (I leave them set permanently) and it's tracking at about 10db higher than usual, but 10db is only a guess.
Was there something in the firmware that set the levels differently, or is there some new setting where you can change the input levels like on the fireface (+4, -10 etc)?
