Topic: Problem (SOLVED): MADI-Sync with Micstasy - Octamic XTC - Madiface XT
Hello
I'm a happy owner of a new Madiface XT and also of a new Octamic XTC
Madiface XT and Octamic XTC work well together over MADI.
But my Micstasy in the circle has obviously problems with the sync-function.
I used it as ID 01 (Auto ID on) and as ID 02 (slave).
The sync function (Optn) works always some minutes and then it obviously lose the signal... in any case the "Optn-LED" begins
to flash and the Sync-LED on the I64 MADI-Card turns off.
Since I use the "Always Single Speed" with all the equipments it seems to be a little better but nevertheless it doesn't work for more than 3 minutes.
One last Info:
I bought the I64-MADI-Card together with Madiface and Octamic. So I don't know whether it works correctly or not.
I repeat myself: Octamic together with Madiface - no problem
Best
www.musik-produktion-createc.ch
