Topic: RayDat Firmware 13 Update problem [SOLVED]
Hi there,
I just found out that RME has new drivers (3.38) with a matching Firmware revision 13 for RayDAT.
I installed the drivers - reboot
I updated the firmware (erasing, writing, success) - shutdown and turn off power.
After this I find that the audio becomes a little flakey in Sonar X3 and sometimes stops entirely, so I go to the DSP Settings and find that the "About" tab displays drivers version 3.38, but nothing about which firmware.
The firmware does now seem to appear in the "Global" as part of the card name in the "Change Card Order" section - and this still displays "Revision=12".
When I run the FUT again it still says RayDAT, Rev. 12 - so I tried to reflash again, shutdown the computer, cut the power, turn the power back on and start the computer - but it keeps telling me it is a RayDAT, Rev. 12
I'm running Windows 8.1 x64 - could that be the cause of the problems?
What else can I do to get the firmware updated to revision 13 so it is aligned with the new drivers?
