Topic: Multiface II Express Card Win7 freeze
hallo,
Recently I racked all my preamps and the Multiface to be able to record also outside my home studio, so I needed a laptop and I bought from a friend an Acer Aspire 5920G because it has an ExpressCard slot, which is disappeared from modern computers... this Aspire is not a light bolt but is enough for just recordings...
But.... there is a problem with the ExpressCard, at the beginning of every session I the system freeze quite often, I need to reboot it manually, sometimes I just unplug the expresscard but usually I get a Blue Screen error.... after few reboots strangely it works for the rest of the day.... last week I did two 8 hours sessions.
I'm already searching a solution for this issue, apparently it has something to do with the power management.
The BIOS in the Aspire doesn't allow me to turn in off, is there any other workaround for this issue?
I also have another question regarding the RME ExpressCard:
when I click it in the slot it's not really locked, I can slide it off without click it in again... is it normal?
thanks
Paolo
