Topic: Buffer settings on new Madi FX
Just changed my old RME config in the tracking room, from a hdsp AES + hdsp 9652 (both PCI -not e), to a brand new MADI FX. Installation went smooth and the specs are exciting, however I cannot get 'decent' buffer values without asio buffer errors in Samplitude/Sequoia ( v11 & v12). On my previous setup on the very same pc, I could go as low as 32 samples, now with the new card I can't go below 256 samples without the dreaded clicks for a simple stereo file playback @44k...
I tried the following:
- updated the firmware to the latest available on the website (Rev 89, DSP 19)
- swapped the card to other pcie slots
- updated graphic card driver and intel chipset driver
- tried several buffer settings within Sampliquoia
- tried different sampling frequencies (48k, 96k)
- tried the 32 channels limit, tried the 1.18 driver instead of the 1.17 (got it from this forum)
- tried an other MADI optical fiber
- installed the card in an other PC (Gigabyte mobo + i5 3570K): same symptoms!
.... but no success. For reference, the other (Gigabyte) PC, runs a good old RME MADI (PCI) card @32 samples without a hicup!
Anything obvious I missed?
Thanks in advance for your help (more specs on request).
Best,
Thomas
MADI FX card sn: 23589637 (as seen from the driver)
Asus p8z68v gen3- i5 2500k- radeon 6670 fanless
Windows 7 64 bit
Samplitude prox suite - Sequoia v11
Direct Out Andiamo XT optical
http://www.sequenza.fr
