Topic: DSP Multiface 1 pcimcia to adaptor i/0 error? help
Hi, I need help.
i bought a multiface 1, with a 15pin cardbus card. a power supply and a cable.
i run windows 7 64, custom pc. i am just installing new windows, i could go back to 32bit since i really only need it for ableton, and i am going to run that at 32 anyways...
i have a texas instruments pcimcia adaptor...
everything looks good ... device manager sees the rme hammerfall... i've installed the drivers and flashed the box with "success" from the flasher thing...
i have a red light.... solid...
the mixer is there...
but on the dsp display, i get
i/o box error...
ive never used rme... i had been using echo for 10 years, i really hope to get this thing working... but i am lost...
i kinda figured if i had flashed with "success" then, the box is talking to the card...
what am i missing... i get no sound...
OH, another thing... is that the analog 1-2 playback is also labeled "speakers" which is wierd...
if i need to run an older driver, thats fine, i just get bad "directions" when searching on the internet, even around here, because the names... well the only difference in terms of searching.. are an added [h ] DSP multiface i [i ] so it is really hard to find anything...
