Topic: RME HDSPe AIO help
I just upgraded to this card, I was using an Echo Layla 3G, which by the way worked on every system I had without any install problems. It was just outdated and would sometimes lock up on my windows 7 machine.
I Installed the card, downloaded and installed the latest drivers. I am running Sonar X1E, 64 bit, windows 7.
The card is recognized, but when I try to open a project or simply add a VST to a single audio track it locks up, freezes the computer, loses audio completely.
I have no idea what to do, I changed PCIe slots and at least started getting sound, but it all went downhill again pretty quickly. I tried ASIO, WDM nothing still the same.
Re: RME HDSPe AIO help
I sent an email to support as well, any idea on how long it takes to get a response?
Have you updated the card's firmware with the Flash Update Tool as well?
Make sure Win 7 is set to use the "High Performance" power profile.
http://windows.microsoft.com/en-us/wind … =windows-7
I tried last evening to update the flash and it froze my computer, had to hard restart it twice.
I will change that setting tonight and try again, thank you!
I put the card in an older computer, was able to install the new firmware. I put the card back into my studio computer and all is well! Thanks, that did it!
Thanks for the feedback. Good to know that my suggestion worked... :-)
