Topic: DigiCheck 5.7 very sluggish
i use UFX for live gigs on an older core 2 duo laptop.. its a model from around 2006.. totalmix FX runs fairly well, its occasionally a little laggy but nothing too bad given the age of the computer..
I recently re installed the OS on the laptop and installed DigiCheck 5.7 on this new install.. I was previously using DigiCheck on this laptop but it was an older release.. Since putting 5.7 on there ive noticed it is really sluggish speed wise, the older release would slow my machine a little, but this is much worse.. When the UFX is set to wordclock or you make any sample rate changes DigiCheck slows to an absolute crawl and brings the machine to its knees.. If you click on something, 10 minutes later the window responds.. I thought DigiCheck was supposed to use little resources on the system and therefore would be ok to run on an older computer ?
does DigiCheck install any other files on the system ? If not maybe i will go back to older release and see how that runs again..
