Topic: UFX, TotalMix and MultiTrack DAW on iPad
OK trying to make it work all together ![]()
UFX is connected via USB (Apple Camera Kit) to iPad (1st Gen) running iOS 5.1.1, with the latest TotalMix app and latest firmware on UFX, all just downloaded/installed.
Front USB port of UFX is powering a SD card reader that records onto 16GB Transcend Class10 card. I'm recording 3 mic channels (9,10,11) at 96KHz. All is well there.
TotalMix by itself seems to work beautifully as controller, so far no issues here. However in addition to the SD card, I'd like to have a duplicate safety recording on iPad. So I bought MultiTrack DAW that was mentioned here on teh forum by RME moderator.
Two problems:
1. As soon as I start MultiTrack DAW, UFX's front panel shows the closk switches from 96K to 44.1K. Why? I thought MultiTrack DAW supported 96KHz recording??
2. In MultiTrack DAW, I set a new track and arm it, then set Source to USB channel. Tried channels 1-8. No sound is being recorded. It seems as if UFX is not outputting to iPad via USB. What am I doing wrong?
Thanks!
Raw4pro.com
