Topic: Question about MADI cables, MIDI over MADI and word clock cable.
Dear RME, I've some questions about the length of MADI and RG59 cables.
Up to now I've used a 50m MADI cable 50/125 (orange) to record audio and carry the MIDI data. The word clock signal is generated from a word clock generator and trasmitted using a 50m of RG59 cable. It works very well but now I need to cover a distance of 100m.
- Is 100m of MADI cable able to carry MIDI data without errors?
- Is 100m of RG59 cable able to carry word clock signal without demaging the audio quality?
- I use a 10m of RG59 to connect the DAW and 50m to connect the stage box (Micstasy), is the difference of length a problem?
- If I use a 100m of MADI cable to cover a distance of 50m and a 50m of RG59 cable for word clock, can I have some problems (sync errors)?
- Does MIDI over MADI need a 62.5/125 instead of 50/125 optical fiber?
Thanks,
G.
