Topic: Moving HDSP Multiface II over to Windows 7 - problem
We have a HDSP CardBus Card (pcmcia with "firewire" plug) that plugs into a Hammerfall DSP Multiface II box.  I had a simple PCI card adapter which converts the PCMCIA card to PCI card since we only run this RME card in a desktop computer.  We have been running fine with a Windows XP machine for the past few years and we just got a newer PC with Windows 7 64bit.  We were using an old version of CoolEdit 2000 on the XP machine, but we have moved to Adobe Audition (CS6) on the Windows 7 machine.
The problem is, on the new windows 7 machine, when I go into Adobe Audition and go to the "preferences" and "Audio Hardware" settings, the "Default Output does not show Analog 1+2 as an option.  It show Analog 3+4, Analog 5+6, and 7+8...along with all the ADAT channels and SPDIF.  On our XP machine, I could see the Analog 1+2 channels in CoolEdit.  Does anyone know why I can't see them with Audition and Windows 7?
Re: Moving HDSP Multiface II over to Windows 7 - problem
I think I can rule out CoolEdit and Audition because if I just go into the Windows Control panel/sound area, in the "playback" section, it does not show Analog 1+2 as a playback device.  I would assume that Audition is just getting it's available devices from Windows, and the problem seems to be Windows does not recognize Analog 1+2 as available devices (by the way, I have enable "the show disabled devices" and it is not listed there).
It might be likely that analog 1&2 are labeled as "Speaker" in Windows?  cool
Anything using ASIO should not exhibit any of these issues.  Are you using the RME ASIO driver in Audition and CEP?
cool
2x SSL Alphalink MADI AX
They are labeled as speaker...now I feel pretty stupid smile
Thanks for the help!
