Topic: Totalmix FX BUG? & Direct Monitoring question
Using the latest totalmix on my HDSPe MADI FX, in the master section i can only select madi 1 1-64 as outputs, i need to select 2- 9/10 how do I do that?
Also the manual states that with Direct monitoring ON the DAW faders can also control the volume of the middle row, but the TotalMix FX faders do not follow the DAW fader position.
Does this mean that in totalmix I should just leave the volume on unity 0dB and "automate" the fader in the DAW?
