Topic: [RESOLVED] Driver 4.04 - WDM not working if FS is 48K
I thought there was a thread about this, but searching for "WDM 48K" did not reveal any hits in the HDSP(e) forum.
I saw this thread: http://www.rme-audio.de/forum/viewtopic.php?id=20543 , but I don't think this is the same issue.
On my home mixdown multipurpose desktop DAW PC (W7-64), I'm running a Muiltiface with HDSPe card and most recent 4.04 drivers (noticed this with 4.03 as well). I'm using 3 Stereo WDM devices (AN1/2; SPDIF and ADAT1/2 - none are assigned as "Speaker"). Runs on internal clock.
I generally don't work @ 48K (I'm always @ 44.1K), but I noticed the other day that if I have the MF's sample rate set to 48K (either manually on the HDSP settings panel or via my DAW/Nuendo 48K project), I can't seem to get any WDM Audio to play. Even if I try to play a 48K file in WMP or VLC using WDM, it won't play if the HDSPe is set to 48K.
As soon as I manually change the sample rate back to 44.1K, WDM audio begins working again. I can play 44.1 or 48K files over WDM as long as HDSPe is set to 44.1K.
Is there something I'm doing to cause this? Would assigning one of the outs as "Speaker" in the DSP settings resolve this? I can't say if I ever tried using WDM @ 48K with the old 2.x and 3.x drivers, but I'm sure I did at some point over the years.
Thanks for any pointers
2x SSL Alphalink MADI AX
