Topic: (SOLVED) HDSPe PCIe card firmware update not working
I have a Multiface 2 + HDSPe PCIe card. I have installed the latest 4.04 drivers & am trying to update the firmware on the HDSPe PCIe card.
Using the latest Flash Update Tool (v2.33), it shows the Hardware revision : HDSP PCIe. Rev 18 & Programming Status : Not updated.
On 1st Update attempt it stalled on 'erasing' for a few seconds then said complete. However after powerdown & restart the hardware revision was still rev 18.
The 2nd time it showed 'erasing' then 'programming' all the way to 100% & appeared to complete successfully. After powering down completely & restarting, the hardware revision is still : Rev 18!
I have tried this multiple times without success. I have tried running as administrator & running without antivirus active but this did not help.
Any ideas what else I could try?
Thanks,
Rich
ps. System: OS = 64bit Win 8.1 Pro; MB = MSI X79A-GD45+; CPU = i7 4930K
UPDATE:
Got it to work!
1: Run the FW update as administrator with the multiface IO unplugged during update
2: After powering down, I switched the slot the HSDPe PCI card was in to a PCIe x1 slot (was in x16 slot)
