1 (edited by fabien 2015-01-02 12:39:44)
Topic: Mapping MIDI Total mix
I would like to map total mix in a midi controller :
The faders of 8 tracks ; the mute ; the solo (8 faders + 2 buttons per track)
The EQ : Gain db Low ; Medium ; Hi, (3 knobs per track)
Eventually the reverb ; delay (2 knobs )
Is this layout envisageable?
Thanks!
fabien
Re: Mapping MIDI Total mix
These are your choices:
8 faders  - see manual, either Mackie protocol or CC. Mute and Solo per channel - only Mackie protocol. EQ - not supported. Reverb/Delay On/Off (or any controls) - not supported.
Using OSC it is possible to control all these. But most probably your MIDI controler does not support that protocol...
Depending on what you need to do, it may be possible to work around TotalMix' MIDI implementation limitations using Mix Snapshots - you can use up to 8 of them and recall them using MIDI messages (notes).
As for the faders, it's a bit easier, see the second post:
https://www.forum.rme-audio.de/viewtopi … 38#p115338
