Topic: Migrating .mix preset files to TotalMix FX - need access to old mixer
I'm rebuilding my studio computer after a catastrophic system drive failure and I've noticed that the new TotalMix FX cannot load the .mix preset files saved with the earlier version of TotalMix that I used to use. I'm a freelance mix/mastering engineer and I have a pretty complex setup for my hybrid analog/digital mastering chain which involves routing audio in and out of my Multiface a number of times for different purposes so it's important that I get back up and running with my original configuration as soon as possible, as I have clients waiting.
After reading this thread http://www.rme-audio.de/forum/viewtopic … 71#p101271 I see that the recommended procedure is to close TotalMix FX, run the old mixer, load a mix preset, flash it to the interface and then run TotalMixFX, resolve the preset mismatch and save the settings in the new format.
How can I run the old mixer? My computer is a fresh install so the old version doesn't exist here, and I don't want to [uninstall current drivers, install an old version, flash the interface with the mixer settings, update drivers, save mix presets...] for each of the 5 preset files I need to transfer.
Can I download an old totalmix.exe from somewhere and just switch between that and the new mixer? It's quite possible that I'm being totally dimwitted here and missing something obvious and I apologise if that's the case and ask that you're gentle with me when you put me right!
All help gratefully appreciated!
Colin
