Topic: Straight to interface?
I am fairly new to recording and need some advice.
Right now I have a Firewire solo and use a Mackie 1202.  I have a few things going into the Mackie and then through the FireWire solo.
But its beyond old and I am looking to upgrade.
If I am reading correctly, I could take a Fireface 800 and just plug everything(2 items) into it, vs into the mixer and then the interface?
Since my setup has always been small, I dont foresee ever going over 1 or 2 connections at a time.  This would remove the mixer and clean up my setup a bit?
Thank you for the advice/suggestions.....
Re: Straight to interface?
Yes, you're correct, no need for the outboard mixer.
Thank you for the reply.  Much appreciated.
