Topic: Multiface II with Version 1 HDSP PCI card ?
Hi again, I was also wondering if it is possible to use the Multiface II with the first generation HDSP PCI card version 1.8 ?
I read that anything earlier than a version 1.9 will not have enough current  to power the Multiface II but have seen some references to using a power supply withe the box. If that is the case, Has anyone done this and what size power supply would be needed for a no issue setup?
Thanks so much.
Re: Multiface II with Version 1 HDSP PCI card ?
The only potential issue is that indeed you might need external power for the MF. Everything else will work fine.
3 (edited by Shadow 2015-02-15 16:35:50)
Hi Daniel, thanks for the reply. So all I need is a power supply and it should work fine? That would be fantastic. I think I would need something more than my cardbus power supply...Can you recommend what volts and amps would be needed?
Thanks again
*edit* never mind.. I see you answered that in my other post...12 volt - 2 amps..  Thanks!
