Topic: Multiface II with Version 1 HDSP PCI card ?
Hi again, I was also wondering if it is possible to use the Multiface II with the first generation HDSP PCI card version 1.8 ?
I read that anything earlier than a version 1.9 will not have enough current to power the Multiface II but have seen some references to using a power supply withe the box. If that is the case, Has anyone done this and what size power supply would be needed for a no issue setup?
Thanks so much.
