Topic: QuadMic II: Two outputs to (unbalanced) stereo TRS line-in
Hello everyone,
I'd like to connect two of the QuadMic II's outputs to a single unbalanced 3.5mm stereo line-in TRS jack on my computer using a short cable.
How should I go about wiring this up? Would it be correct to connect is as follows?
QuadMic Output 1 Tip -> Line-in Tip
QuadMic Output 2 Tip -> Line-in Ring
Both QuadMic Output 1 and 2 Sleeves -> Line-in Sleeve
The last point is the one I worry about. Is this safe? Is it perhaps better to connect just one of the outputs' sleeves?
Thanks!
Chris
