Topic: The Multiface II can drive headphones Beyerdinamic 250 ohms?
Good morning,
currently use on my Multiface II headphones AKG K240 MkII which has only rated impedance of 55ohm, 200mW maximum input and 104dB / V sensitivity. Despite the favorable characteristics for use with the integrated amplifier in the MF II, the volume is a little low.
Reading on various forums I learned that not only is the impedance of the headphone to define the volume but the efficiency per milliwatt. For this reason I decided to buy a headset Beyerdinamic 250 ohms.
I am undecided between the DT770 Pro and DT880 Pro
I would get an improvement? Or is it better to use a headphone amplifier?
Thanks, greetings
Carlo
...I forgot, I produce electronic music
