Topic: Non destructive Solo in place - is it possible?
I am mixing my live mix during a recording with TotalmixFX. Is it possible to Solo input channels to my monitors without soloing them on the main mix?
Let's say I have my main mix to 1-2.
I am listening to this with Phones1, which are routed to 3-4 and mirror the output 1-2.
Solo destroys my main mix.
I can switch to PFL and send PFL to Phones1, that works.
But if I want to listen to single microphones with the correct panning and fader this is not possible.
Did I miss something?
Of course this question only arises, because TotalmixFX is getting better and better, and I love the new mirror feature!
Georg
Re: Non destructive Solo in place - is it possible?
What you can do is removing the sync between the two outputs by using Copy instead of Mirror at a certain point. Otherwise there is no way to let Solo do work differently, and PFL is indeed the exact solution intended for this.
Thanks Mathias,
Yes copy would work, but only as long as I do not change my mix. And I do it constantly.
Maybe you could think about implementing a non destructive solo bus somewhere in the future. All we would need is an option to define main/phones as our Solo bus.
As far as I can see the design is already there in TotalmixFX, all we would need is a different solo behaviour.
Thanks for considering.
Georg
