Topic: submix to 2 outputs
I would like to send the same sub-mix simultaneously to two different outputs (AES and Phones2 on a UFX). Instead of coping the sub-mix from one output to the other (which would yield two separate sub-mixes; meaning that, for example, moving one channel’s fader would only effect the one output associated with that sub-mix), I want to be able to make changes in the one sub-mix (adjust a channel fader or EQ, for example) and have the changes effect both outputs.
               |---> AES
Sub-Mix |
               | ---> Phones1
How do I do this?
Re: submix to 2 outputs
By using the option Mirror (since TM FX 1.10) instead of Copy.
As long as it is just one stereo copy you can also use the workaround mentioned in the manual via Cue.
