Topic: submix to 2 outputs
I would like to send the same sub-mix simultaneously to two different outputs (AES and Phones2 on a UFX). Instead of coping the sub-mix from one output to the other (which would yield two separate sub-mixes; meaning that, for example, moving one channel’s fader would only effect the one output associated with that sub-mix), I want to be able to make changes in the one sub-mix (adjust a channel fader or EQ, for example) and have the changes effect both outputs.
|---> AES
Sub-Mix |
| ---> Phones1
How do I do this?
