Topic: DigiCheck as a vst plugin ?
Is there a plan to make DigiCheck as vst plugin ?
I'm using software room calibration plugin (Sonarworks) as last plugin in Cubase. So I need to visualisation plugin insert BEFORE room correction. I love DigiCheck but now it shows corrected signal and its useless in this situation.
OR maybe there is solution to DigiCheck shows hardware outputs signal and not playback from DAW ?
Pawel
Re: DigiCheck as a vst plugin ?
You just need to route the audio (before the room correction) to an unused output pair and use this for DIGICheck monitoring.
Thanks for reply. I guess I need to route audio inside DAW not RME TotalMix ? Im using Cubase 8 and Studio One 3 pro. In Cubase I see some way but in S1 i don't know...
4 (edited by Dandruff 2015-06-17 13:26:19)
Yes, you need to do this routing inside the DAW so that DIGICheck can see the unaltered signal.
Thank you for help. Its working in Cubase 8 Pro. I routed in VST connections main out to 7-8. And control room to 1-2. Then DigiCheck shows playback from 7-8. I'v try do second buss in Studio One 3 Pro but no luck. Im using this DAW for 2 weeks so maybe Im missing something.
Pawel
Not familiar with Studio One. But I guess it's possible with it too.
Anyone tried to solve it in Ableton Live 10?
there is no control room...
i want:
- to hear processed sound with Sonarworks plugin
- to see unprocessed signal in Digicheck
8 (edited by ramses 2019-04-22 13:02:46)
I think it's important to get also this point in the discussion:
DIGICheck works as ASIO client and gets the data directly from the HW via ASIO driver.
This is independend of any DAW.
BR
Ramses
X10SRi-F, E5-1650v4, Win10Pro21H1, Cub11Pro, UFX+, XTC, 12Mic, ADI-2 Pro FS R BE, RayDAT
9 (edited by tasty_mushroom 2019-04-22 13:20:49)
found solution for Ableton..
outist is a maxforlive device that lets you route any signal to any internal or external destination.
https://gumroad.com/l/vDPJ
