Topic: Mystical problem with TotalMix FX and OSX
Hi.
I have really strange problem: TotalMix won't start up most of the time (it starts up something like 1 time out of 50 without any clear reason i can think of).
OSX 10.9.5 (Mac Book Pro)
Babyface
Firmware: v223
Driver: v2.10
TotalMix version: 1.12 MAC OS X (1)
Everything have been fine so far about 3 years with my Babyface. But now after session with Fireface 800 the TotalMix FX won't start up with my Babyface anymore. I have been removed all RME software and reinstall everything with latest drivers but still it won't work. Mystical is that now it have started few times ok but then when shutting down and try to start again it only crach...
2 (edited by mikael 2015-06-16 13:36:00)
Re: Mystical problem with TotalMix FX and OSX
Update:
Ok now it goes like this: first when i connect my Babyface nothing happens and task manager says that TotalMix FX not responding, but if I wait for 5 minutes it just gets alive and start working. But it shouldn't work like that. It should start up right away without waiting for minutes... It used to be plug and play until yesterday.
Mystical problems need mystical solutions...
Try this: plug your Babyface in. Note the exact time. Wait for Totalmix to appear, note the time again and don't use your Mac while waiting.
Next, open up the Console app, from Applications/Utilities/
Find the time you plugged in the Babyface and copy all lines till the end. Post these here.
I suspect one of Apple's extensions is trying to prepare a Time Machine backup, indexing Spotlight data, or sending stuff to the cloud. Could also be something like DropBox or Soundflower. But the Console errors will usually tell what software is blocking Totalmix.
Hi cyrano,
Am having exactly the same problem as Mikael describes, but with a Fireface UC - this has only started happening since I downloaded a driver for an old FireFace 400, which I have since completely uninstalled, although Totalmix still takes around 5 minutes to load
I also completely uninstalled Soundflower, but no luck there...
Anyway, below are the lines from Console.
The exact time I plugged in the Fireface was 12:56:02, and TotalMix finally loaded around 13:01:06
Any help would be much appreciated!
Cheers,
Matt
15/02/2016 12:56:00.852 com.apple.xpc.launchd[1]: (com.apple.midiserver[636]) Service exited due to signal: Abort trap: 6
15/02/2016 12:56:00.852 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:56:00.857 ReportCrash[634]: Saved crash report for MIDIServer[636] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125600_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:00.858 ReportCrash[634]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125236_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:11.080 com.apple.xpc.launchd[1]: (com.apple.midiserver[641]) Service exited due to signal: Abort trap: 6
15/02/2016 12:56:11.080 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:56:11.085 ReportCrash[634]: Saved crash report for MIDIServer[641] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125611_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:11.086 ReportCrash[634]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125246_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:16.479 spindump[601]: Saved spin report for TotalmixFX version 1.12 MAC OS X (1) to /Library/Logs/DiagnosticReports/TotalmixFX_2016-02-15-125616_Matthews-MacBook-Pro-2.spin
15/02/2016 12:56:21.312 com.apple.xpc.launchd[1]: (com.apple.midiserver[643]) Service exited due to signal: Abort trap: 6
15/02/2016 12:56:21.312 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:56:21.317 ReportCrash[634]: Saved crash report for MIDIServer[643] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125621_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:21.317 ReportCrash[634]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125256_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:31.542 com.apple.xpc.launchd[1]: (com.apple.midiserver[644]) Service exited due to signal: Abort trap: 6
15/02/2016 12:56:31.542 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:56:31.547 ReportCrash[634]: Saved crash report for MIDIServer[644] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125631_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:31.548 ReportCrash[634]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125306_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:41.572 com.apple.xpc.launchd[1]: (com.apple.ReportCrash[646]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
15/02/2016 12:56:41.803 com.apple.xpc.launchd[1]: (com.apple.midiserver[645]) Service exited due to signal: Abort trap: 6
15/02/2016 12:56:41.803 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:56:41.824 ReportCrash[646]: Saved crash report for MIDIServer[645] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125641_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:41.824 ReportCrash[646]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125317_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:52.040 com.apple.xpc.launchd[1]: (com.apple.midiserver[647]) Service exited due to signal: Abort trap: 6
15/02/2016 12:56:52.040 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:56:52.045 ReportCrash[646]: Saved crash report for MIDIServer[647] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125652_Matthews-MacBook-Pro-2.crash
15/02/2016 12:56:52.046 ReportCrash[646]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125327_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:02.265 com.apple.xpc.launchd[1]: (com.apple.midiserver[648]) Service exited due to signal: Abort trap: 6
15/02/2016 12:57:02.265 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:57:02.270 ReportCrash[646]: Saved crash report for MIDIServer[648] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125702_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:02.270 ReportCrash[646]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125337_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:12.497 com.apple.xpc.launchd[1]: (com.apple.midiserver[649]) Service exited due to signal: Abort trap: 6
15/02/2016 12:57:12.497 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:57:12.502 ReportCrash[646]: Saved crash report for MIDIServer[649] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125712_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:12.503 ReportCrash[646]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125347_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:22.732 com.apple.xpc.launchd[1]: (com.apple.midiserver[650]) Service exited due to signal: Abort trap: 6
15/02/2016 12:57:22.732 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:57:22.737 ReportCrash[646]: Saved crash report for MIDIServer[650] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125722_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:22.738 ReportCrash[646]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125358_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:32.963 com.apple.xpc.launchd[1]: (com.apple.midiserver[651]) Service exited due to signal: Abort trap: 6
15/02/2016 12:57:32.963 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:57:32.968 ReportCrash[646]: Saved crash report for MIDIServer[651] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125732_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:32.969 ReportCrash[646]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125408_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:42.996 com.apple.xpc.launchd[1]: (com.apple.ReportCrash[653]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
15/02/2016 12:57:43.230 com.apple.xpc.launchd[1]: (com.apple.midiserver[652]) Service exited due to signal: Abort trap: 6
15/02/2016 12:57:43.230 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:57:43.251 ReportCrash[653]: Saved crash report for MIDIServer[652] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125743_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:43.252 ReportCrash[653]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125418_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:53.459 com.apple.xpc.launchd[1]: (com.apple.midiserver[654]) Service exited due to signal: Abort trap: 6
15/02/2016 12:57:53.459 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:57:53.463 ReportCrash[653]: Saved crash report for MIDIServer[654] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125753_Matthews-MacBook-Pro-2.crash
15/02/2016 12:57:53.464 ReportCrash[653]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125428_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:03.693 com.apple.xpc.launchd[1]: (com.apple.midiserver[655]) Service exited due to signal: Abort trap: 6
15/02/2016 12:58:03.693 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:58:03.698 ReportCrash[653]: Saved crash report for MIDIServer[655] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125803_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:03.699 ReportCrash[653]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125439_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:13.920 com.apple.xpc.launchd[1]: (com.apple.midiserver[656]) Service exited due to signal: Abort trap: 6
15/02/2016 12:58:13.920 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:58:13.925 ReportCrash[653]: Saved crash report for MIDIServer[656] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125813_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:13.926 ReportCrash[653]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125449_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:24.151 com.apple.xpc.launchd[1]: (com.apple.midiserver[657]) Service exited due to signal: Abort trap: 6
15/02/2016 12:58:24.151 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:58:24.156 ReportCrash[653]: Saved crash report for MIDIServer[657] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125824_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:24.157 ReportCrash[653]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125459_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:34.379 com.apple.xpc.launchd[1]: (com.apple.midiserver[658]) Service exited due to signal: Abort trap: 6
15/02/2016 12:58:34.379 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:58:34.384 ReportCrash[653]: Saved crash report for MIDIServer[658] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125834_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:34.385 ReportCrash[653]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125509_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:44.412 com.apple.xpc.launchd[1]: (com.apple.ReportCrash[660]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
15/02/2016 12:58:44.643 com.apple.xpc.launchd[1]: (com.apple.midiserver[659]) Service exited due to signal: Abort trap: 6
15/02/2016 12:58:44.643 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:58:44.664 ReportCrash[660]: Saved crash report for MIDIServer[659] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125844_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:44.665 ReportCrash[660]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125519_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:54.877 com.apple.xpc.launchd[1]: (com.apple.midiserver[661]) Service exited due to signal: Abort trap: 6
15/02/2016 12:58:54.877 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:58:54.882 ReportCrash[660]: Saved crash report for MIDIServer[661] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125854_Matthews-MacBook-Pro-2.crash
15/02/2016 12:58:54.883 ReportCrash[660]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125530_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:05.109 com.apple.xpc.launchd[1]: (com.apple.midiserver[662]) Service exited due to signal: Abort trap: 6
15/02/2016 12:59:05.109 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:59:05.114 ReportCrash[660]: Saved crash report for MIDIServer[662] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125905_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:05.115 ReportCrash[660]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125540_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:15.337 com.apple.xpc.launchd[1]: (com.apple.midiserver[663]) Service exited due to signal: Abort trap: 6
15/02/2016 12:59:15.337 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:59:15.342 ReportCrash[660]: Saved crash report for MIDIServer[663] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125915_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:15.343 ReportCrash[660]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125550_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:25.566 com.apple.xpc.launchd[1]: (com.apple.midiserver[664]) Service exited due to signal: Abort trap: 6
15/02/2016 12:59:25.566 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:59:25.571 ReportCrash[660]: Saved crash report for MIDIServer[664] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125925_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:25.572 ReportCrash[660]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125600_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:35.802 com.apple.xpc.launchd[1]: (com.apple.midiserver[665]) Service exited due to signal: Abort trap: 6
15/02/2016 12:59:35.802 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:59:35.807 ReportCrash[660]: Saved crash report for MIDIServer[665] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125935_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:35.807 ReportCrash[660]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125611_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:45.831 com.apple.xpc.launchd[1]: (com.apple.ReportCrash[667]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
15/02/2016 12:59:46.065 com.apple.xpc.launchd[1]: (com.apple.midiserver[666]) Service exited due to signal: Abort trap: 6
15/02/2016 12:59:46.065 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:59:46.086 ReportCrash[667]: Saved crash report for MIDIServer[666] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125946_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:46.087 ReportCrash[667]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125621_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:56.293 com.apple.xpc.launchd[1]: (com.apple.midiserver[668]) Service exited due to signal: Abort trap: 6
15/02/2016 12:59:56.293 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 12:59:56.298 ReportCrash[667]: Saved crash report for MIDIServer[668] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125956_Matthews-MacBook-Pro-2.crash
15/02/2016 12:59:56.299 ReportCrash[667]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125631_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:06.522 com.apple.xpc.launchd[1]: (com.apple.midiserver[669]) Service exited due to signal: Abort trap: 6
15/02/2016 13:00:06.522 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 13:00:06.527 ReportCrash[667]: Saved crash report for MIDIServer[669] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-130006_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:06.528 ReportCrash[667]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125641_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:16.752 com.apple.xpc.launchd[1]: (com.apple.midiserver[751]) Service exited due to signal: Abort trap: 6
15/02/2016 13:00:16.752 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 13:00:16.757 ReportCrash[667]: Saved crash report for MIDIServer[751] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-130016_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:16.758 ReportCrash[667]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125652_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:26.981 com.apple.xpc.launchd[1]: (com.apple.midiserver[752]) Service exited due to signal: Abort trap: 6
15/02/2016 13:00:26.981 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 13:00:26.986 ReportCrash[667]: Saved crash report for MIDIServer[752] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-130026_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:26.987 ReportCrash[667]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125702_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:37.211 com.apple.xpc.launchd[1]: (com.apple.midiserver[753]) Service exited due to signal: Abort trap: 6
15/02/2016 13:00:37.211 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 13:00:37.216 ReportCrash[667]: Saved crash report for MIDIServer[753] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-130037_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:37.217 ReportCrash[667]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125712_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:47.243 com.apple.xpc.launchd[1]: (com.apple.ReportCrash[755]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
15/02/2016 13:00:47.474 com.apple.xpc.launchd[1]: (com.apple.midiserver[754]) Service exited due to signal: Abort trap: 6
15/02/2016 13:00:47.474 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 13:00:47.495 ReportCrash[755]: Saved crash report for MIDIServer[754] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-130047_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:47.496 ReportCrash[755]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125722_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:57.700 com.apple.xpc.launchd[1]: (com.apple.midiserver[756]) Service exited due to signal: Abort trap: 6
15/02/2016 13:00:57.700 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 13:00:57.705 ReportCrash[755]: Saved crash report for MIDIServer[756] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-130057_Matthews-MacBook-Pro-2.crash
15/02/2016 13:00:57.706 ReportCrash[755]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125732_Matthews-MacBook-Pro-2.crash
15/02/2016 13:01:07.932 com.apple.xpc.launchd[1]: (com.apple.midiserver[757]) Service exited due to signal: Abort trap: 6
15/02/2016 13:01:07.932 com.apple.xpc.launchd[1]: (com.apple.midiserver) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
15/02/2016 13:01:07.937 ReportCrash[755]: Saved crash report for MIDIServer[757] version 145.4 to /Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-130107_Matthews-MacBook-Pro-2.crash
15/02/2016 13:01:07.938 ReportCrash[755]: Removing excessive log: file:///Users/Matt/Library/Logs/DiagnosticReports/MIDIServer_2016-02-15-125743_Matthews-MacBook-Pro-2.crash
5 (edited by cyrano 2016-02-16 00:58:12)
MIDIserver is crashing, restarting, crashing...
I have no idea why, cause I don't use MIDI.
If your RME driver, firmware and OS are up to date, try deleting caches.
The easiest is to download a tool like Cache Cleaner from Northern Softworks:
http://www.northernsoftworks.com/
See if that helps. Possibly some part of the old drivers is still around (a plist that misleads launchd into starting something old).
If you are at ease with the Terminal, it's even simpler:
sudo purge
will also do it. Reboot immediately after, of course.
If your system software is an upgrade version, it might be time for a clean install. In that case, it's wise to make a clone on an external disk, with Carbon Copy Cloner or Disk utility. To do it with Disk utility, you need to start your machine from other media. You could use the Recovery partition, but that only has a command line version of Disk utility.
This is an OSX bug, triggered by an Intel bug. You'll see this a lot if you look for it:
There is no single fix for it...
6
We do not see this error on our machines. Here are some steps to try:
- delete and rescan the MIDI configuration in Audio MIDI Setup
- in Finder first copy (backup of TM FX settings) then delete the folder /User/.../Library/Preferences/RME TotalMix FW and the file de.rme-audio.TotalmixFX.plist
- in case MIDI is not needed at all: under  "/Library/Audio/MIDI Drivers" delete the FireWire MIDI driver "Fireface MIDI.plugin". No problem as it will be back with a driver reinstall. You could also delete the USB 3 driver MADIfaceUSB3MIDIDriver.plugin.
Please report back if one of these help.
Thank-you both for your swift responses!
It seems that deleting the "de.rme-audio.TotalmixFX.plist" and "Fireface MIDI.plugin" has done the trick so thank you MC
