Topic: Correct/Logical routing for hardware inserts
I have watched the tutorial videos several times and generally understand the workflow of Totalmix, but I must be missing something as I'm struggling to achieve what I want.
I use Cubase 7.5 and have set up some "Hardware Effects". The routing as far as cables/interface I/O is all correct.
I'll use an example scenario:
Channel 5 - Mono compressor
Channel 6 - Mono compressor
Channels 7/8 - Stereo EQ
As you'd expect with an insert, I want to hear the dry signal when the plugin is in bypass, and I want to hear the full wet signal when it is active.
Instead, I seem to have to change back and forth between monitoring the Cubase master bus output and monitoring only the return signal of the hardware chain (so I don't hear both at the same time).
Can a Totalmix expert PLEASE help me out with step by step instructions? I am sure there must be hundreds of people utilising hardware inserts, (doesn't matter if you use Cubase or not as all DAWs that support inserts work the same way pretty much).
Many thanks in advance!
Cheers,
Dylan
