Topic: Best Wordclock cabling between RayDAT WCM Module, UFX, OctoPre
Hi
I am about to buy a RayDAT with WCM module additionally to my current setup
I need advice in terms of best Wordclock cabling and best technical results (WC jitter, etc)
In this PDF you see 3 different cabling scenarios
https://dl.dropboxusercontent.com/u/961 … ctoPre.pdf
"Option A" - two RG-75 cables originating from the RayDAT WCM WC out ports
"Option B" - in series without T-connector
"Option C" - in series with T-connector
My questions:
1) are all 3 cablings (option A-C) technically valid (pls look, whether termination is proper at all devices)
2) do you agree that "option B" is probably the best solution
I personally like "option B" because:
- I only require one additional RG-75 cable (3m in length between RayDAT and the rack with UFX and OctoPre)
- I do not require a T-Connector, so one part less which might become broken ...
Thanks a lot
