Topic: TM 1.12 doesn't restore workspace properly (level of main)
I am using UFX and RayDAT in the same system, all works really great, only 2 issues where I hope you can support me on that.
I created a new TM window and am controlling UFX in one and RayDAT in the other TM window.
I configured TM to "always init DSP devices with TM settings" (for both interfaces).
After configuring the routing and everything I finalized by storing the settings for both devices:
- in a snapshot (right hand side, one of the 8 slots)
- via File -> Save Snapshot as (uniqe filename per device)
- via File -> Save Workspace as (unique filename per device)
- via Workspace Quick Select, slot 1 for UFX, slot 2 for RayDAT
2 Problems now:
- TM doesnt remember the workspace layout and I need to manually load a workspace via "Workspace Quick Select".
It would be good, if one of these workspaces could be set as default
- After restoring the settings via "Workspace Quick Select" the level of the Master Output fader for the RayDAT in the
second instance of TotalMix is not like I saved it. I wanted to have 0dB, but it is set to -10dB
Could you kindly give me a hint how to fix #2 ?
If you could think about implementing #1 would be a great thing towards user friendliness.
Thanks a lot upfront !
