Topic: Faders stuck in totalmix
Hi!
I just installed an older Multiface 1 with a PCI card in a Z400 HP workstation.
I cannot select any output to setup a mix. I cannot select anything for that matter.
I cannot move any input faders.
Only the software return fader assigned to windows can be adjusted.
I tried clearing the mix, f2->preference->disable D2D
I made sure the PCI slot was not set to "Compute" in the HP bios.
Firmware and drivers are the latest.
What's going on?
