Topic: Frustrating Problem with 9632 Installation
Hey Friends,
I'm writing to you because I can't see what is wrong or what I did wrong. I worked through the Manual of my new HDSP 9632. So I first plugged the Soundcard into my PCI-Bus. After this, the HDSP was recognized by the PC successfully and I installed the new driver for version 4.12. Everything went fine so I restarted my PC and after Booting successfully it shows that the Soundcard was installed successfully (all I/O-Channesl were shown in the "Sound Devices" Window). The Card itself is also shown as "working with the newest drivers" in Devices Manager...
So... after setting up ("Settings") the HDSP to make ANALOG 1/2 Channels as an output I switched to my PC Sound Devices and selected the Channel as standard sound output to make the parallel STEREO Headphone Output work (because I wanted to listen via Headphones).
But.... I CANT get any sound signal. this drives me nuts after all these days. If I "test" the Soundcard (Richtclick-> Test) nothing happens - no sound and no changing soundlevel. If I start music (Windows Media Player and VLC) nothing happens either.
I already updated my BIOS. But it didn't change anything. I don't know what to do. The RME Support I contacted couldn't help me. Maybe you guys have a hint what I can do to fix this ? I would be so thankful....
Have some relaxing Christmas days!
btw. Iam using Windows Vista 64bit. Having a AMI - Motherboard from 2011
