Topic: 2 x hdsp 9632 and spdif sync
I need to use the internal spdif (sync & out) pins on the 2 x HDSP 9632 cards as I no longer have the external spdif cables.
Do I connect the "Sync" pin on one card to the "Out" pin on the other card? Is this all I need do or also connect the remaining "Out" to "Sync" as well so i use 2 cables?
The manual refers to "Clock mode master" but I don't see this.
On the "Hammerfall DSP settings under windows 7 64bit there seems to be 3 related options. How do i get this in sync what do put in the following for each card (The card with cable connected to "Sync" & the card with cable connected to "Out")
SPDIF In:
Optical
Coaxial
Internal
TMS
SPDIF Out:
Optical
Professional
Emphasis
Non-Audio
Clock Source:
Internal
Word Clock
Adat
Spdif In
Thanks for any help with this
Cheers
