Topic: SOLVED hdspe 407 driver does not work with OSX 10.11.6 & Logic 10.2.4
I've just installed the latest hdspe 407 driver version in clean installed El Capitan 10.11.6.
Now Logic 10.2.4 can't receive Midi messages from my master keyboard (Digiface shows the incoming messages via Led but they do not reach Logic Pro X). If I go to the Mac OSX Audio MIDIi Setup, the MIDI Setup window will not open its content and takes Total Mix out of work as well (both programs are not responding anymore)
The hdspe 407 version works fine with Logic 10.2.0 in Mavericks on my other ssd
I have two HDSPe PCI cards installed but only one Digiface connected to one card at the moment. Therefore OSX Audio MIDIi Setup states a Multiface for the PCI card that has nothing connected (I have a second Digiface that I could connect if an "empty" card has something to do with the issue I have)
If not instantly fixable I like to go back to the hdspe 406 version and try it with Logic 10.2.4 in El Capitan 10.11.6.
How do I uninstall the current 407 driver if I like to go back to 406 -or will the 406 version just override the current 407 version?
Thanks in advance
