1 (edited by Juan.Pablo.Cuervo 2008-03-12 20:34:27)
Topic: #1. Adi-4 dd #2. Adi 192 dd vs. Adi-8dd spectrograph & RMAA tests
[large]#1.[/large] my first question its about the Adi-4dd & SteadyClock(TM) with a lower jitter ext. W.C.
my concern/fear about Rme Adi-4dd is that the SteadyClock(TM) will mess the hi.quality lower jitter Master WordClock signal
Ive seen that some RME products have a "follow clock" on/off feature "i assume its an SteadyClock(TM) bypass", but i dont see that feature reading the Adi-4dd .pdf manual.
i dont understand yet, how the SteadyClock works in the Adi-4dd without an internal W.C.
i just want to remove all jitter, "not nearly" from my synths that does not have a W.C. input::
for example::
                          <+/-1ppm Master WordClock@48.K
Kenton plugstation--adat-->("adat--->aes/ebu box")--->SRC--->Soundcard--->hi quality DA
but $1500us.dls for Adi-192dd ?.
i probably will use the Adi-4dd + 4x behrnger src2496, becouse i dont know if Alesis Ai-1 its 24-bits or 20-Bits or 16?
or the new Lynx Aes16e-SRC or Rme aes32
or... one of each brand of hardware SRC to test A/B and sell the ones i dont like::
  behringer src2496
  z-sys zlink96+ has same chip as z3src & lucid src9624, cs8420, "the important its whats surrounds the chip",
  Mytek 192 SRC,
  Lucid src9624
  Lavry LE3000S
or similar units with W.C. input like tc electronic finalizer plus/96k
there are other adat--aes/ebu boxes, i know of: Aphex 144, discontinued Alesis Ai-4 & Rme Adi-8dd, otari fs-96, mutec, digidesign 192 digital , etc...
Rme Adi-8dd seems more attractive becouse it comes with XLR i/os = save $250us. of the RME BOB32 or >two digisnake mh080 + hosa xlr-f - xlr-m
[large]#2.[/large] maybe ill consider the Adi-192dd if i see some Spectographs & RMAA tests vs. Adi-8dd & others, z-link96+, Mytek SRC, Behringer SRC2496, Lucid src9624, tc electronic finalizer plus/96k, Otari Fs-96, etc...
  like this:
http://www.bias-inc.com/products/peakPr … ePaper.pdf
and RMAA tests of the SRC
http://audio.rightmark.org/
[large]#3.[/large] Whats the SRC latency in samples of the Adi-8dd ?
Re: #1. Adi-4 dd #2. Adi 192 dd vs. Adi-8dd spectrograph & RMAA tests
looking ::
http://www.rme-audio.com/english/adi/adi8dd.htm
seems that Adi 8dd does not work for me, becouse the SRC only works with the Aes/Ebu inputs, i need the outs
3 (edited by Juan.Pablo.Cuervo 2008-03-14 18:10:24)
http://src.infinitewave.ca/
this web page its amazing...!!!!!!!!!!!!
Weiss saragon vs. z3src vs. almost all software !!
sadly its missing tc electronic finalizer plus & 96k, the new konnekt x32, otari fs-96, Lynx, Rme, Behringer src, Lucid src, Lavry 3000s, Mytek Src, sonifex.co.uk src, Assemblage D2D-1 Sample-Rate Converter, Dolby Lake Processor, etc...
