Topic: UFX+ crash over long USB 3.0 cable
I just get the UFX+ and I cant get it work.
I need a 5 meters cable to go from my desk to the machine room, I tried different settings.
1-plug directly on my PC with the inbox short cable : UFX shows as an UFX USB 3, working
2-plug with a 5 meters extension USB cable : UFX sometime shows as a UFX USB 2, not working, totalmix wont show up, blue screen, computer freeze.
3-plug on an USB 3 powered hub with the short cable then the hub on the 5 meters extension cable : getting windows error message "Super speed Port bandwidth exceeded" : not working
4-plug with short inbox cable into an active USB cable then to the hub : not working
I found that kind of cable, its a fiber glass USB cable
https://www.amazon.com/Optical-Cables-C … B00JOJRF6K
Before to buy it I'd like to know if it can work as those cable are not powered, a solution may be to use the short cable, plug it on the hub then plug the hub to the pc using the usb optical usb cable.
I'd like to know if someone of you guys are using a long USB 3 cable what kind of cable are you using.
any help appreciate
Thanks in advance.
