Topic: ADI-2 Pro - quick presales questions if I may?
Hi there
I'm currently considering my options in respect of a DAC and a preamp. This is for a home environment using high end power amps and speakers. Currently not using headphones much - but that is on my 'todo' list.
I did a quick search in the Pro music field and not surprisingly came across the ADI-2 Pro quite quickly. So I skimmed the very informative 88 page manual so have a fair idea of what is what. But just wanted to double check if the ADI-2 Pro will work in my set up. Hope someone can give me confirmation (or not) that things will work.
1. Will the volume control work on the analogue outputs when I have digital and analogue mixed inputs? For example USB input (for PCM/DSD) and line level analogue input?
2. Can I trim the sensitivity on the analogue inputs to match the digital inputs? or vice versa?
3. I have two power amps (via a high quality relay switch box). Can I output two identical feeds from the ADI-2 Pro (with volume control - as per first question).
Edward
London, UK
I hope I posted in the correct section - please move if not.
