Topic: Sample rate and format changing for input 1/2. How to.
Hi all,
How to setup more than 192Khz sample rate or change from PCM to DSD?
Clock menu is gray.
Only one way changing sample rate is do this in DigiCheck. But again no more than 192 and only PCM.
Re: Sample rate and format changing for input 1/2. How to.
Sample rate in USB operation is changed in the Settings dialog and requires Internal Clock mode and no ASIO software running. See manual.
I'm read this in manual. But how to record input analog signal to comp via USB with PCM 768?
4 (edited by jchan 2017-04-01 16:50:21)
Recording with what software? Pro Tools Native its max 192 (HD 384/768). But for OS X sample rate must be changed in audio / midi setup
5
He uses Windows, but you are right, it is the software where this is set then - if possible. DIGICheck is limited to 192 kHz operation as well. For example Reaper can do.
DSD is greyed out as long as the sample rate is below 176.4 kHz.
