Topic: Micstasy outputs vs passive mic splitter
I am researching options for a backup recording rig and wondered whether sending the Micstasy analogue outs to a UFX w/DURec (or similar) at the same time as recording the digital outputs (either ADAT or MADI) is immune from ground loops?
Or would I be better off using a passive mic splitter to send the mic outputs to the Micstasy and UFX (with the Micstasy providing 48v)?
The same question goes for the Octamic II, thanks.
Eastwood Records
www.eastwoodrecords.co.uk
Re: Micstasy outputs vs passive mic splitter
Use balanced cables (XLR female to TRS) and there will be no ground loops.
The OctaMic II doesn't have line outputs.
Thanks MC. I thought the Octamic had TRS line outs?
Eastwood Records
You're right. For whatever reason I was thinking about DA conversion...
