Topic: Totalmix FX won't start with OSX 10.10.5
If TMFX does not start under OSX 10.10.5, please try the following steps:
  • Open the finder and navigate to Macintosh HD > Library > Audio > Plug-Ins > HAL
  • Copy "Avid CoreAudio.plugin" e.g. to the desktop (just to retain the file)
  • Delete "Avid CoreAudio.plugin" in the HAL Plugin folder
  • Reboot
RME Support
Re: Totalmix FX won't start with OSX 10.10.5
Thank you, I have tried to do that but there is not such a folder "Avid CoreAudio.plugin" inside "HAL"
3
https://www.forum.rme-audio.de/viewtopi … 10#p115510
There are more plug-ins that can cause apps not to start. The below information is from Native Instruments support section:
Additionally, we have learned that the plugin files listed below may also cause similar problems when launching an NI application:
    "RazerAudio.plugin"
    "Hear.plugin"
    "SoundBunny.plugin"
    "Digidesign CoreAudio.plugin"
As these files are likewise found in the HAL folder, the procedure to manually remove these files remains the same as explained above.
SoundBunny was the culprit for an RME user where TotalMix FX would not start.
Thanks!
