Topic: AO4S-192 AIO not showing up in Totalmix after connection to HDSP 9632
I need some help here. I just received a brand new AO4S-192 AIO (I bought it from a private person, but the box was wrapped in plastic and the card clearly never used). I inserted it in my pc, connected the flat cable to my HDSP 9632 PCI (not PCIe).
After rebooting, I still have only two analogue outs in Totalmix. The same applies to Cubase.
I am on Win 10x64. I use the version 4.12 RME driver.
Do I have to do some kind of setup in Totalmix to activate the four outs on the AO4S?
Please help me out.
Best,
Magnus
Re: AO4S-192 AIO not showing up in Totalmix after connection to HDSP 9632
OK, so after I restarted the computer, the four new outputs showed up everywhere. Awesome! I don't know if I am only imagining this, but running my headphone amp from the AO4S seems to sound better than before, when I had the amp connected to the headphone output of the HDSP 9632...
Anyway, as long as the outputs keep showing up, I am one happy camper!
/Magnus
Hm, I guess I need some help, since this is what shows up in Totalmix when playing a wavfile in Windows.
http://web.comhem.se/inventions/downloads/Tmix.JPG
I have no Adat equipment at all. The physical connection is from Analogue 1 and 2 (the outs of the HDSP 9632), yet Totalmix seems to believe it is playing the sound and outputting it through ADAT 5/6...
I would at least need some clarification here, please...
/Magnus
Read this to learn how to set the correct output channels for Windows playback:
https://archiv.rme-audio.de/download/wi … er_4_e.pdf
And here
http://www.tonstudio-forum.de/blog/inde … rnal-equi/
http://www.tonstudio-forum.de/blog/inde … al-Videos/
Thanks MC and ramses for those links. I will read through the material. Everything works as it should anyway, so no problem really. Just a bit confusing...
/Magnus
In my blog article I cover basic operation of TM to the point in german and english.
By this you will learn required basics which will be of good help for any further routing demand.
Thanks, ramses, that is fantastic and extremely helpful. I read German well so will probably try that version first.
Best,
Magnus
