Topic: UCX + UC buying advice needed
I got an UCX and been thinking I should buy a used UC and hook it up via ADAT. Basically using the UC as a ADAT expansion to my UCX.
1. Is that a viable setup?
2. In 24 bit 48kHz I'm getting 8 out and 8 in via ADAT right? Or are there any specific restrictions with the UCX and UC?
3. What happens if I connect both via USB to my Windows 10 computer? Can I use TotalMix with both? Like switch between them to set routing? Or does this only work if I have two UCX?
