Topic: ARC USB via a USB 3.0 hub
I would like to use the RME ARC to control the UFX post computer, like a traditional analogue monitor controller. This is so I can 1) turn down/mute the volume after any potential pops or freakouts from the PC in the event of a crash, and 2) also use run sound with the PC off.
Will this setup work if I connect the ARC and UFX to a hub, then the hub to the PC?
(I am thinking the UFX can see the ARC thru the hub without needing the PC/TotalMix):
[UFX] / [ARC] <—> [USB hub] <—> [PC with TotalMix]
