Topic: Windows 10 recording problem
I am enjoying my new ADI-2 Pro but I have encountered a problem when recording to PC from the analogue input. I have the unit in ADAC mode so that I can hear the analogue input while it is being recorded in 384KHz 32bit float mode. I record one side of an LP and then test the recording by playing back in USB mode. I then switch back to ADAC mode and record the second side to a completely new track, but when I try to play the second recording it plays with extreme distortion at what I suspect is double speed as if half of the samples have been lost or possibly only 16 bits have been saved for each sample. I have had the same thing happen with two completely different recording programs and even on two different computers ( both windows 10 Pro with the latest patches and updates). If I save the bad recording it is approximately half the file size I expect. Nothing on the ADI display shows any unexpected or different values.
Could this be an ASIO driver issue?
