Topic: ARC USB does not light up all 3 buttons?
Hello all - I'm new to RME. I just picked up a Fireface 802 and ARC USB controller. So far so good, learning a lot.
My problem is when I plug in the RME ARC USB only the first 2 lights (Talkback, Speaker B). DIM will not light up, which according to manual means it has not established communication with TotalMix FX.
I'm sure this is a very simple solution, but I couldn't figure it out.
I do have a midi keyboard (Akai MPK49) plugged into the Fireface midi ports (standard 5 pin midi cables). And I have established connection with my DAW (Reason), so that is working.
The ARC USB is plugged into the computer (via external USB hub). Could this be the problem? Do I need to only plug ARC USB directly into one of the computer USB ports?
In the Settings of TotalMix there is a "MIDI" tab and an "Aux. Devices" tab. I believe both my Akai and ARC are showing up in multiple areas. Should I only focus on the "MIDI" tab? I'm confused about which tab is responsible for which device?
Last question - since I bought the Fireface used, it seems there were some previous settings saved by the previous owner. For instance some channels are panned L or R. Is there a way to reset the entire TotalMix FX software and Fireface just like it was new out of the box?
Thanks all!
